Okay.This may make it clear.''That was a single conductor not sized in accordance with NFPA 780 taking a direct hit from lightning.''
Ok I have stayed quite on this thread for a while to kind of see which way it would go, and I see that we have an argument without proper knowledge in the subject of lightning science, As kind of pointed out a few things in post 22 lightning does not follow the fundamentals of what many of us here understand in electrical theory, it is a science in its own realm, here is the one main thing that most do not understand and that I also pointed out in post 22, lightning has a high frequency component, it has a fast rise time and decay and will in all strikes cause oscillations even before the the lightning hits its target, this many times can steer the lightning as to what it is going to be hit at that time, while this effect is not yet fully understood but if you have any training into how radio waves work and how an antenna has to be close to the resonating frequency of the signal before the electrons can build up on it, then you can understand how lightning can see a 15' tall tree with branches of many different lengths (broad band antenna) and not even attempt to strike a well grounded 300' tower not more then 50' away.
This theory is also the bases why we see lightning take strange paths that just don't make sense to the average electrician, but if you can understand that when you apply radio theory it becomes clearer, I have seen lightning follow some of the most backwards paths that one would think if it was trying to go to straight Earth, in one case it struck a phone trunk line and instead of going to a service it was bonded to, that not only had two ground rods and a city water pipe that ran for miles underground, (this I know for fact our water lines are not isolated) it followed a small 2 pair 28awg phone wire outside over 60' to the other side of the house where it can close enough to a chain link fence where it arced off to and never damaged anything but the phones in the house, the small phone wire was vaporized up to the fence but after that was totally intact and usable, this is just one of the many strikes I have been on over the years.
Growing up in Florida was why lightning was such an interest to me, I was following storms all across Florida, spent many hours camped out about a mile of some very tall TV towers, one was over 1700' just north of Orlando, Fl. I have seen the damage of what was once called "super lightning" (positive stroke) can cause, I did a 3 year intern at the University of Florida before Camp Blanding was being used for regular rocket launches by them and others, I have done some of my own experiments with towers and setting up many towers and grounded them using many different methods, and using old Hawk Eye flash lamps to set up a way to know when which tower received a strike, the strange thing (was back then) I learned was even with all these grounded towers in this field, lightning would hit the trees more then anything else, and after I learned the reason why (as I posted above) it all started to make sense.
Am I an expert in lightning? far from it, I never got the chance to carry out the many experiments that would be required to bring all these theory's into the realm of a fact, but I do believe I have a good understanding at some of the things it does and why, at least enough to know what is a myth or not, and this is still one of the areas that keeps coming back is old myths that get many to believe something that which is not a fact.
The one fact that there has been papers written on, is that lightning is a high frequency event but it is also a variable and depending upon many factors can vary as low as 20hz to over 1 Ghz but most frequently is centered around 1Mhz but it is not un common to find low cloud lightning at 10 Mhz, and if you can start to calculate the impedance and wave length of conductors with these frequencies in mind, you will start to draw a picture of how little effect grounding can be, a given wire at a given length can have a resonating wave length and impedance if the frequency is known, but this is the problem! We just don't know what the frequency is going to be, and this is why it will always be a hit and miss, which is why my statement in the last sentence of post 22
