ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Just to be clear about what I have been saying all along, in a case where there are multiple connection points to a conventional SMA inverter (yes, I know that on a SBxxxx with integrated DC disconnect they are inputs to a combiner, not multiple inputs to the inverter itself), a common practice is to home run the DC+'s to the inverter (yes, to the integrated combiner located at the inverter) and to combine the DC-'s at the array.Both, yes, but not (one and not the other), parentheses added for clarity. That's what SMA told me, anyway. The SMA guy could have been mistaken.
In the case of a Sunny Boy transformerless inverter with multiple inputs (as in http://www.solar-net.nl/zonnepanelen/files/images/Manual-SMA-SB2100TL.pdf, see page 22 for the two DC inputs), if you combine the DC- connectors at the array you must also combine the DC+'s, because the current in a DC+/DC- pair must be the same on both conductors, because of the way that that inverter detects ground faults, because in a transformerless design the DC- is ungrounded and measuring current between the DC- and ground will not detect a fault. In a transformerless SMA inverter a fault is detected when a difference in current between DC+ and DC- is sensed, and the inputs are monitored separately.That's how a SMA field rep explained it to me, and I was passing it along as an answer to the question about what is different about transformerless inverters.
He may have been mistaken, and in which case I am as well. So sue me. ;^)
