Coastal
- Kill Devil Hills, NC
Help me figure this one out. I have a 150 Amp main breaker disconnect being fed from the meter socket. SER is feeding from the main lugs of the disconnect to a 150 amp main breaker sub panel in the house. I get 240 volts across phases at the main lugs of the disconnect, as well as 120 volts to nuetral and ground. In the house panel, I get 120 volts from each phase to neutral and ground but nothing between the two hot legs. What could possibly be happening to the feeder between the disconnect and the sub-panel to be causing this?
