- Massachusetts
It has been posted here before but I cannot remember the name of the product you can pour into a conduit ahead of time to get old wires out.
Thanks in advance
			Thanks in advance
Aqua regia?
Thanks in advance
Discuss the issue within earshot of a local crack head. The wire will be out the next day with no work on your part.
I once had this problem with large wire about a 200 ft run that had to be pulled out of some 4 inch rmc that had been under the slab for 25 years. We actually broke a large pull rope trying to pull it with a tugger. I had access at the gear to the pipe going down into the floor. This pipe was in the boiler room of an old junior high school. I got a garden hose and hooked it up to the hot water line and stuffed it in the pipe and taped it upr good. ran the hot water til it came out the far end and ran it til it was hot at the far end. let the whole mess sit overnite and whadda ya know. we were hooked up for the pull the next am and out she comes. a bit slushy but the wire came out real easy nevertheless.A rather low tech way of doing it but it worked like a charm. cheap too!
An outfit nearby has a product called CableFree Loosener. It is made at the American Polywater Corp..
That was the one I was thinking of, Thanks.
Unfortunately I cannot de-energize the conductors until the night I plan to change them and when I checked that products instructions it says you have to kill them first.
It is a 75' long of walker duct filled with 12 AWGs, but floor wax has been spilling into it for a long time and has glued the conductors in place.
UUUUUHHHHHHHHHHHGGGGGGGGG
Walker duct gets some nasty nasty stuff in it over the years.
Yeah ....... :lol:
This one is under line of supermarket cash registers, it is surprising the stuff that gets in them.
And maybe, the walker ducts used for data lines with out boxes at each opening might make great mouse tunnels ...........
