tyha
- central nc
we have an RTU that was not marked and the mech cont is not availible. Comming inside the unit we were told , of course, because this is a an RTU the heat strips are part of the unit and are put together with this box that looks like where we come in at. this box isnt attached to anything but has 3 lugs with 60 amp fuses comming off each and wires going outthe other side. Im assuming the mechanical cont wires past the fuses but my question is because nothing is mrked on the outside of the unit and the plans call for #4's with an 80/3 CB can we feed with 60 amp because that is what it is fused at anyway. the plans on this project have been wrong in almost all other areaes due to a load of changes. Im guessing the box is called a connector box or something that connects the comp and the heat strips
