Talley1013
- Houston, TX
Is it code compliant to use a 120v photocell to switch one leg of a control circuit for a 240v lighting contactor coil(one leg directly to coil, other leg wired through photocell w/ neutral)? I am installing a new contactor that unfortunately is 240v in a situation that already has a 120v photocell installed w/ wire pulled to the LP/photocell. If it is OK I would like to use the existing wire/photocell. Thanks.
ET
ET
