When running conduit what is typically used for allowing conduit to expand when running conduit across expansion joints or other areas that are open to expansion. In the past I've seen "flex conduit" used to allow for this expansion. I wanted to see what was typically used/specified in such expansion cases. Do others specify/use flex conduit or some other type of expansion fitting?
Particular application is a 2.5" RMC conduit across a structural expansion fitting.
