Have you ever heard of any substance behind the "three threads engaged" argument?
To make for a cleaner looking install, we use a 4x4x36" trough under our PV inverter and related components, with EMT up to each. Engineers will definately not be OK with just using the locknuts, they actually call out bonding bushings all around (PITA)! Anyhow, I like to put a seven hole ground bar in the trough and send a EGC through each conduit, and it's quick and easy to tap a hole or two for the mounting screws. I'm being advised that this should be through bolted because I can't guarantee three threads of contact? If that's the case how are all these 4 square boxes out there bonded?
Anything to make things more complicated I suppose?!
1/8" = 2 threads, no?
because I just drill a hole in the back of the trough, into the sheetrock or plywood behind and thread the hole with my triple tap. To add the nut (one more thing to find a spot on the van for) now I have to make a hole in the wall where the nut lands so the trough sits flat to the wall. Or mount to the bottom of the trough, now I need a stubbly flat head to tighten the terminal screws. (those terminals have a torque spec, right? How do I get my torque driver in there?)
Was quick and code compliant, now slightly less so.
The screws that come with the ground bar are 8/32, are enclosures a minimum thickness to get their listing?
I like to use a more common sense view...Is a metal trough with EMT, locknuts, EGCs in every pipe, bonding bushings, and a ground bar field installed by a licensed electrician effectively grounded? Will it provide a reliable and robust path for fault current? I would hope so. And sometimes common sense aligns quite well with code compliant, and I believe this is the case in this instance.
Sometimes I wish I worked for/with any one of y'all.
But alas...destined to think I'm doing right, but somehow always wrong!
