Marky Spike
- Arlington, Washington
Let?s say you had a surface mounted panel and a disconnect next to each other about 2 ?? between them, and they are in a closet with approx. 1 inch of clearance on each side of both combined. (Including handle of the disconnect)
The question is; if applying NEC 110.26(A)(2)
Would you be required to provide the 30 inches from the center of the panel and then 30 inches from the center of the disconnect, or would you simply consider the width of both combined constitutes the clear space (which ends up being approx. 41 inches)
Any and all insight is appreciated!:thumbsup:
