Rescently was instructed to wire a motor 230 volt to a 2 pole breaker into a 230 volt panel. The oringinal motor was a 120v motor controled automaticly. The 230v motor was install on temp bases because of a delivery problem and had to be controled by a worker turning on the cb evry hour or so till new motor arrived in less than 12 hrs.
The wiring was complient to nec but the operator who had to turn cb on claimed it is unsafe to turn cb on . The panel was closed with both the dead front and outside panel cover nothing exposed except the cb handle to 20 amp cb motor was 3/4 hp unit. Operator was instructed what to do and when, he said he was fine with that . One of his coworkers was not happy and complained its unsafe.
Is he right about it being unsafe to operate cb ?
