electriciangirl
- Oulu, Wisconsin
I was called to look at a water heater that has an intermittent problem with the reset button on the unit tripping. All replaceable parts on the water heater have been replaced, elements and thermostats. The breaker at the breaker panel has never tripped. I was not able to find any shorts or wiring problems. Would a build up of excess heat in the access area where the reset button is located cause this to happen? It seems to happen when they are using a lot of hot water.
