I was working on a hot tub today that was being fed by a 50amp gfci breakr. This gfci breaker feds a sub panel by the hot tub that has a regular 2pole 30 and a 2 pole 20 in it. The 2 pole 20 feds whatever and has a neutral. The 2 pole 30 feeds the heaters and requires no neutral. It seems to me that there would be no gfci protection on the heaters because there is no neutral, hence requiring a gfci breaker for both the 20amp and 30amp breakers in the sub panel instead of feeding the whole sub panel with a 50amp gfci. Am i thinking right. I hope this makes sense.
