howardrichman
I'm installing switch, outlet and lighting aluminum weatherproof boxes throught a horse barn. I'll be installing wet location type fixtures, and covers on all the devices. Would I have to use stainless steel screws to fasten the boxes, and pipe straps? I wouldn't use them on exterior work; unless the code referes to specific areas where there might be a corrosive atmosfere. Also; would the outlets and GFI's have to be rated outdoors near or at the stall areas? Will i need to ground toggle switches in metal boxes? I'll be installing a few paddlefans above the stall isles; cant find a commercial weatherproof fan. Will a standard unit pass inspection mounted to an approved wp fan box? All pvc piping, aluminum boxes, inspector will not allow EMT.
HR
HR
