I inspected a service today to check its grounding. It had been upgraded in the last 5 years. They did not use the metal underground water pipe from the city utility. They drove two ground rods instead. Would you hook to the city water? And if you did would you unhook the ground rods? It also seems that there is still a ground wire comming from underground that goes to the POCO meter. I asume it goes to the neutral lug. What are your thoughts?
Thanks
Thanks
