I was under the impression that you could only have 6 mains on a transformer. According to art 450.3(A) note #2 if I have no secondary overcurrent protection then I can have as many overcurrent devises as I want as long as they are not over 125% of the transformer rating. Is this true? Can I have a 40 circuit panel with no main on the load side of this same transformer. The line side of the transformer is protected with 125% of the rating of the transformer. This 40 circuit panel is a lighting panel. In the case of a motor control panel. Can I have a 10 circuit panel on the load side of a transformer with only the proper size overcurrent on the line side of the transformer?
