petersonra
- Northern illinois
- Semi-retired engineer
I mentioned this once before but I may be in need of having the house phone system rewired. there is a horrible static noise on it coming from somewhere. Right now the only phones working are the cordless ones. The base station is plugged directly into cable modem.
Is there any simple way to redo the wiring? I have a crawl space under most of the house so there is no real access that way.
I talked with an electrician acquaintance about this once before and the numbers he was coming up with make me want to leave it as is.
I am thinking if I do this it might make sense to have Ethernet wires run at the same time. It has been suggested to me that given as the telephone only uses 2 wires a cost effective setup is to run cat5e and use 2 of the 4 pairs for data and run the phone lines in one of the unused pairs. There is something about this idea that bugs me that I cannot quite put my finger on.
The other thing that bugs me is the idea of running the cables in the crawl space and having them lay on the crawl space floor, something else that was suggested as being the only practical option.
