dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I work in an older facility that constantly needs updating and I was hoping someone could clarify somethings for me that I believe would fall under the catagory of separately derived systems.
We have a 480v ungrounded delta system that runs from several pieces of switchgear to various areas throughout the facility via overhead lines for machinery and various services. My question deals with properly converting the 480v to 120/240 for receptacles hand tools, coffee makers, lighting, water heaters, AC etc.
Our current method used during the original 1950s installation was to tap 2 legs off of the 480v from the overhead feed connect them to a transformer at floor level, then run from the transformer secondary about 5feet to a panel an Aphase Bphase and use the center tap as the neutral and connect these to the 120/240 service panel. At the service panel a ground is ran from it to the building I beam and connected via drilled and tapped hole.
Finally the questions
In the service panel should the neutral be connected to the gnd using the grounding screw in the panel like a regular residential service?
Is this method of using the I beam adequate for grounding or does a secondary gnd have to be added?
