Does anyone know why a switch is not required at the door to a room or outside.
For commercial, I understand. Residential, nope.
Now someone is going to blast me with " it is a design issue" mantra, oh well.![]()
IT'S A DESIGN ISSUE!!!!
90.1(C) "This code is not intended as a design specification or an instruction manual for untrained persons."
Now with that said there a many code requirements that may well be a design issue and not a practical safeguarding issue.
Chris
The thought is why require a light outside a door if I have to walk upstairs to turn the light on. More than likely no one would do that. If it is a safety issue then a switch should be installed at each door. Yes? NO?
Yeah, yeah. But gramma does not understand why the kitchen overhead light is controlled by a switch in the basement.![]()
The NEC only requires a lighting outlet not a luminaire. So I could put a j-box on the outside of the door and meet the requirements of 210.70(A)(2)(b).
If we are going to require switches by the door how far from the door are we permitted to place the switch?
Chris
Actually the NEC requires a switch controlled lighting outlet. There is an except for automatic means 210.70.
I am not saying there should be but the code requires a light yet does not req. the switch to be "X" feet from the door/s.
You missed my point, it was not with the switch but the term "Lighting outlet" which is just a j-box not a luminaire.
I could put a switch controlled j-box on the wall and meet the requirements of 210.70(A)(2)(b).
Again the NEC does not require a luminaire to be installed on the exterior side of a door, just the lighting outlet.
Chris
Chris
How is it a lighting outlet if no light is attached.![]()
Yep, I think that argument of not installing a light would not make it in most of the real world.Because I intend to attach a luminare to the j-box someday.
Chris
Actually the NEC doesn't require a 3-way for stairs either, you could just put a SP switch at each landing to control a fixture at each landing, as per the wording in the NEC.The only requirement for switch locations in located in 210.70(A)(2)(c) for stairways.
The NEC does not require 3 way switches for hallways and rooms.
The locations of switches is a design issue not a code issue.
Chris
