jeff48356
- Livonia, Michigan
If I were the local electrical inspector of my city, I would add the following requirements for every house sold, before a certificate of occupancy can be obtained:
1. Separate 20-amp circuit required for garage outlets, no other outlets allowed on circuit. One outlet in ceiling for door opener, and at least one outlet on each wall.
2. Separate 20-amp circuit required for outdoor outlets, no other outlets allowed. One outlet required on front, back, and driveway side of house.
3. All ceiling fans must be controlled by a light switch and a speed control knob on wall. No pull-chains allowed to be used. (This is in addition to the requirement that they need to be installed on a fan-rated ceiling box.)
4. All hallways greater than 8 feet in length must have a recessed light within 3 feet of each end, and every 6 feet of additional length in between. A 3-way switch is required near each end, and if hall is 16 feet or greater, a 4-way switch is required with one in the middle as well as the ends.
What changes would you make, and what is your opinion of the ones I just mentioned?
