- Windsor, CO NEC: 2023
- Hospital Master Electrician
I'm looking for a small (500W - 1000W) UPS to direct-wire into a residential branch circuit. Any ideas?
			I should have added that I don't think you are permitted to turn off emergency lights with a switch. If the power goes out, they come on irregardless of the switch position (although I do not have a code reference to back that up).
Maybe these are non-required emergency lights?
Thanks for the replies, guys.
I'm thinking at this point that it would be cheapest and easiest to simply throw a small toggle into a $30 frogeye and call it a day. Quick and simple.
This is to provide emergency or power-fail lighting? Would a lighting inverter be a better choice than a general purpose UPS? (I haven't looked at the costs of the latter.)
I just looked into emergency lighting inverters, well over $1500 per KW.
