I did a job where I installed the owners three low voltage pendant lights. The instructions said that a electronic low voltage dimmer be used if dimming is desired. The owner had the same exact lights installed in a different part of of the house that are on a regular line voltage dimmer. These lights are 2 years old and the lights and the dimmer still work fine.
What can happen if you install a regular dimmer switch on low voltage fixtures? because there is a huge difference in cost between an electronic low v dimmer and a regular dimmer. I went with the low v dimmer just to cover myself.
