JOHNEO99
- Northern Illinois
Hello,
I have been looking at a job where the facilities manager wants to add the 5-AHU's to the back-up generator. Here is the scenario as I see it. There is a 175K Gen Set feeding a 400 and 200 ATS both 208/120v. From the 200 AMP ATS it goes to a 200 amp 42 circuit panel board for life safety circuits and there are three breaker spaces unused. The 400 AMP ATS goes to a 400 amp emergency equipment distribution panel with 42 circuits and there are also three breaker spaces unused. It also has two sub-feeds: 100AMP breaker for telecommunication room panel, 200 AMP breaker for a disco feeding a boiler switch board. The gen set is running at 28-30% on their monthly checks.
I am trying to get the 100 AMP panel for 5- AHU's (which draws about 40 AMPS) that is fed from a switchboard to be fed from the back up generator but everything is filled up on the existing emergency equipment and life safety panel boards minus the three breaker spaces left over which I don't think I can use as they are not rated for a sub feed? Plus I would think I would need a visible disconnect for the AHU panel.
Ive gone through a number of situations in my head to try and figure out how to make this work by code and don't feel comfortable with one yet. I think the generator can handle it but need to find a way to include the new load.
Any suggestions would be helpful.
