mivey
Concerning the nature of voltages, directions, and electromagnetic induction.
There have been a few threads discussing the directions used for positive voltages. Of particular interest were the smaller voltages taken from the center-tapped winding of a single-phase transformer.
Some contend that the positive direction for both voltages must be in the same direction and that using the center-tap as a reference point does not produce "real" voltages. Several reasons are given, including that it is easier, that the single flux in the core mandates it, and that doing otherwise will result in breaking electrical laws, physics laws, and will result in voltages that are math tricks instead of real voltages.
I contend that the positive direction is arbitrary because: By definition, the reference point of a voltage is arbitrary. Also, the "positive" direction of an AC voltage is not defined in one direction and it is we who arbitrarily pick a positive and negative direction.
I contend that we can pick either direction as positive and that doing so will result in real voltages without breaking any laws of electrics, physics, etc.
Some basics:
We can attempt to use the instantaneous direction given by magnetic induction to say that one direction is positive and one direction is negative. That is mis-representing what the directions from induction are telling us because those directions only tell us what is happening with the forces at any given instant. The magnetic induction will tell us that the instantaneous forces in the winding are all "in-phase" and creating forces in the same direction. It does not tell us what direction is permanently defined to be positive or negative.
There are no laws that define what direction we have to use as a positive voltage direction and what direction we have to use as a negative voltage direction for all time intervals.
There are no laws that tell us what point is the "one true reference point" for a voltage. By its very nature, voltage is a relative value and the zero reference is completely arbitrary.
More on "the laws" next.
Some basics:
Potential energy and zero reference.
Potential energy is the capacity to do work. Potential energy is an integral function of force and as such, has a constant of integration. This constant can be set to any value needed to establish a desired zero point for the potential energy. Because this constant is arbitrary, the point of zero potential is completely arbitrary, although we usually pick the zero point by convenience or some logical choice. Because the point of zero potential is arbitrary, it is the difference in potential that has physical meaning to us.
Electric potential and zero reference
Electric potential energy per unit charge is also called electric potential and is measured in volts. Voltage is the difference in electric potential between two points. If an electric field exists between points A & B, and is directed from A to B, the electric potential rise from B to A is equal to the work it would take to move a positive unit charge from point B to point A. Because of the arbitrary constant of integration, the point of zero electric potential is completely arbitrary, although we usually pick the zero point by convenience or some logical choice.
Instantaneous direction for an electric field.
An electric field exerts a force on both positive and negative charges. We call the force that the field exerts on a positive charge to be the positive force direction, and thus the direction of the electric field. With this definition of the electric field direction, we say an electric field is radially outward from a positive charge and radially inward towards a negative charge.
Direction for an AC field.
The voltage with the AC we are most familiar with is represented by an alternating sinusoidal wave and the direction of voltage rise changes every 1/2 cycle. A point charge in the alternating electric field will experience a force in one direction for 1/2 cycle, then a force in the opposite direction for 1/2 cycle. The zero reference point for the measurement of the electric potential for that point charge is arbitrary.
For this potential, the capacity to do work increases to a maximum, then decreases back to zero during each 1/2 cycle with no set positive or negative direction for the full cycle. A positive or negative direction is a choice that we make.
