Sure as long as the pigtail is at least as large as the largest egc in the bunch.When terminating EGC's in a panel and the ground bar does not have enough terminals, is it permissible to splice several ground wires under a wirenut with a pig tail to the ground bar??
I did not know this, you learn something new everyday. I guess I figured you would have to upsize the EGC so I never looked into it. I guess it's not likely to have faults on multiple circuits at the exact same time so it wouldn't matter, eh?
