Nameplate? Only if you're the original installer and have no way of telling what the actual use will be.
Thermal overloads ("heaters") are there to protect the motor- unlike the fuses / breakers that are pretty much useless in protecting the motor. Heaters, with their slow response, completely ignore the usual starting currents, etc.
The usual procedure is to operate the equipment in it's "normal" manner and size the heaters as small as you can, until nuisance tripping becomes an issue. This is just about the only way to protect the motor from single-phasing, without designing an entire control cabinet. It also lets you know when a bad bearing, etc., is placing additional load on the machine.
Why else would the heaters be made in such a variety of settings?
