The situation is a galvanized gas pipe rusted out in this installation. This is a natural gas pipe feed to a gas meter on the other side of the gas meter; (load side) the gas was bonded. The gas was bonded by coming from the ufer ground, then hitting the gas pipe, then going into the meter can (no ground rod was used). Per 2005 250.52 (3) Could the ufer ground have been compromised by the installation of visqueen being used as a vapor barrier under the slab and up the sides of the footer?
The gas pipe, however, instead of going into the house, went back into the ground where it was brought up into the house from the outside (40-50' away) and at different locations, gas cook top, pool heater etc.
The question I have is wether this method caused the gas pipe to become a grounding electrode? The other question, if yes, what code specifically was in violation? 250.52(A)? Another part of the question would be; would these same violations exist for 1999-2005? I know now that galvanized is no longer permitted and the yellow coated stainless is being used.
Last question (if anybody knows), should dieelectric unions have been used at each point of entry out of the ground and into the house? Would this of had any effect?
