I know this has been adressed before and I've searched but I have a few questions pertaining to my situation. What I have is a 2" underground feed from the utility into a 200a all in one, the meter is on the left side then feeds to the 200a main breaker on the right with 2/0 or maybe 3/0 cable. I'm installing a 20kw genset with a ats rated as a service disconnect. I would like to set the ATS right next to the panel, then remove the cable from the 200a main breaker, splice it with polaris connectors, run it to the ATS, then back to the 200a breaker.
I would normally scrap the whole setup but now the utility requires minimum 2 1/2" conduit and I don't want to replace this conduit as it would cost a whole lot of pennies.
Question#1.) 312.8 How do I total the space including the panelboard?
Question#2.) Any problems with running the feed from the meter to the ATS then back in the same conduit, I can't think of one?
Question#3.) I don't understand what I need for grounding with this unit?
Question#4.) Anything else that I should be looking at while doing this, I cannot have the inspector tell me FAIL and not get power back the same day on this one, I'm alittle scared, ok a whole lot scared.
Thank you for any help that you can provide me. I'm very new to the trade and trying to learn it.
