If you don't mind my asking what did you get per pound on your #1 and larger stripped? Around here we get .15/lb more for "bright". Alot of guys still burn off their wire in outside fires out in the "back 40". Sure makes for a colorful display when all those toxic chemicals start dancing around. Back when copper was at it's peak(3.45/lb) I spent a couple of hours and hand stripped about 150' of 500mcm, nice days pay for a couple of hours work.
This is from my ticket:
#1 insulated wire, 191 lbs, 1.55/lb  (NM, UF, #2 AWG RH, single cond THHN, TW, etc)*
AL cans, 2 lbs, .60/lb  (Soft drink & beer cans)
Irony old sheet, 16 lbs, .30/lb  (AL meter bases)
#1 copper, 33 lbs, 2.65/lb  (Bare CU, #14 to 2/O)
Old sheet, 4 lbs,.40/lb  (Bare AL wire, foil, pie pans, etc.)**
Irony brass, 1 lb, 1.00/lb (piece of CU water pipe with valve)
Insulated AL wire , 23 lbs, .15/lb (#10 to 4/O insulated AL)
Bare Bright, 25 lbs, 2.75/lb  (Bright bare CU, #14 to 2/O)
*I don't understand #2 RH bringing same price as NM & UF. NM & UF have more paper & insulation material & less weight after processing. UF is tedious to strip, by any method I know of. Smaller single conductor, #14 to #8, should pay more than NM, I would think.
**I had 2 buckets full of sheet scrap & 2 nearly full buckets of bare AL wire, #8 up to 4/O. I'm pretty sure I had more than 4 lbs. I think a bucket got missed on the scale or misread. I don't understand bare AL wire being graded with old sheet, but the .40 price is about right for wire. Most places I've been class bare wire to itself. I also don't understand irony old sheet, meter base being more valuable than insulated AL wire. Removing iron rivets & brackets is more tedious than stripping insulation.
I had a total of $464.10. I was expecting between 450 to 600. I won't lose sleep over it, but I think I lost some value in my bare AL and better insulated CU.
After parking, I unloaded all the buckets trash can & bundles. I laid them out in good order. 2 guys came & picked up buckets, 2 each, etc. They put some on scale, made entry, put more on, made entry, cleared scale, etc. I guess the scale could subtract previous weights,etc but if operator was to do it, something could have been miscalculated. No chance to recheck later, as they poured into their containers as it went off the scale. I should have asked with each container(s) what grade it would be & insist they clear the scale after each batch. I don't doubt their honesty but I look back & question the procedures a bit. I do plan to take them a load of steel scrap & see how that goes. They are among the few that buy all grades of steel.
