qcroanoke
Sometimes I don't know if I'm the boxer or the bag
- Roanoke, VA.
- Sorta retired........
This is the type of AC unit I believe the OP is talking about.
They get installed at ground level outside cell tower enclosures and cable TV head end sites.
The only thing inside is the intake and discharge grills.
A receptacle within 25' is required on the outside of the building as per 210.63.
We install the same type of units on our shelters only the Mfgr. is Bard.
Every shelter gets an exterior receptacle within 25 ft. of the units.
Only thing serviceable from the interior is the heat strips and most of those are serviceable from the exterior also.
I did notice that the units had disconnects mounted on the wall but the units also have a disconnect installed in them behind that flap on the back of the unit.
We do not do mount disconnects if the unit has a disconnect installed in it.
