electricus
- wisconsin
It doesn't make sense to me to put a 15A light switch on a 20A ciruit, but I'm being challenged and can't find the exact information to back it up.  I think it would make sense to just put the circuit on a 15A OCPD if 15A switches need/want to be used.  So what is the correct answer for this, 15A switches on 15A circuit, have to use 20A rated switch on a 20A circuit?
There is another instance where there is a movable table with a hard wired light and light switch, it is cord and plug connected to the nearest hardwired (building) receptacle to were ever it is placed at the time. Is it allowable to have a 15A rated switch on the cord and plug connected table, even thought it may be plugged into a 20A circuit? If something like this is built how does one determine what the ampacity of the conductors and switch, if a 15A cord cap is used does this make the difference that now the whole this is "15A" rated. How does this compare to cord plug tools, like a shop vac for instance which might only have a 18/3 for the tool cord and it is plugged into a 15A or 20A circuit.
By the way all these examples are 120VAC.
