KVA
- United States
I know nothing about bonding how much would this cost me? I only do residential and light commercial.
Most AWJ here require a bond. Most are just $5,000 performance bonds. Really just a way to make sure your a legitimate company.
well, in calif. you can't have a active c-10 without a bond.... it's $12,500, and costs about $150 a year or something.
If you want to run afoul of the CSLB, just advertise your $12.500 bond. $150 a year is rather high, mine is only $195 for 2 years, but am going to put the C10 lic. on inactive status, so it expires at the end of the year.
yeah, i just pulled that out of memory.. the last time i renewed, it was $110 a year....
i went and looked....
Well I hope for you that it will be that cheap on your renewal, good luck.
i don't understand the running afoul thing.....
you can't have an active license in calif without a bond,
so why is it a problem to say you have one?
Yes you can get into trouble for advertising you are " Bonded" This is one of those reduculous Ca laws. The reasoning is that All contractors are required to be bonded and if you advertise as such then you are acting like you are better than those that do not.
You can't advertise you're bonded when you are!?!?
Wow. Simply WOW.
Not reall bad if you think about it. Every licensed must have the basic bond to have a valid license so either you are licensed or not!
Yes you can get into trouble for advertising you are " Bonded" This is one of those reduculous Ca laws. The reasoning is that All contractors are required to be bonded and if you advertise as such then you are acting like you are better than those that do not. Same goes for Advertising that you are insured, you must specify what type of insurance in the ad. So you cannot say" Insured and bonded" but you can say " Gen Liability insured and performance bonded or key keeper bonded". I would not advertise either.
