michael mckague
 - connectitcut
If you can believe it, my first encounter with a ballast disconnect(factory installed) the male 277 pin had fell out and was waiting like a trap. Lucky for me I caught it before  anything bad happened. Before you remove that ballast cover always assume that its live, you could turn off that circuit and all the lights around the fixture your working on could go off, but your fixture could be on a different circuit(night light). By the time you verify if the circuit is off, you have already handled it, making it impossible to truly work on it and claim the power is off.  These disconnects might even make it more dangerous, I do not trust them and its sad the code forces us to use them.
