HVAC Load calculator
mike30jr
New member
thomasville, GA
I am currently bidding a job that requires feeding thirty seven mini split ac units out of two panels. I was looking for the load calculator for hvac equipment, and found that it usually calls for you to figure hvac equipment at 100%. I was just woundering if this is the case for a total hvac fed panel. This seems to be a huge load, and wanted to make sure that this is right?
When the temperature is highest or lowest (or beyond) the temperature the systems were designed for they will be 100% loaded, and the users would sure appreciate that they continue to run at those times.
