Scob
 - Dothan, Alabama
A customer wants to add individual utilility meters to his two (2) outdoor lighting loads and one subpanel load. The plan is to feed a two gang meter socket from the existing 400A Main, 480V/277V Main panel and then feed from the load side of each meter socket to two (2) new subpanels for the lighting loads and add one meter between the 40A breaker in the Main Panel and the existing subpanel load, all of this wiring can be done under 10 feet. Each existing lighting loads are spread across six (6) 40AMP 3pole 480V breakers, for a grand total of 12, these 12 breakers will be moved to the new lighting subpanels.
My quesitons are: 1. Is a new breaker required in the Main 400A panel to feed the two gang meter socket? or does the 10ft tap rule apply, also can this wiring be sized based on the individual lighting loads or both added together? 2. Do the new lighting subpanels require a main breaker?
