Resistor for heat light.
Benton
Louisiana
I have a heat light that i thought had a faulty motor because when I put power to it the motor wouldn't run. After taking it down for replacement and futher inspection I found that there was a resistor that was between the incoming hot and the beginning of the element. I jumped this resistor with a piece of bare wire and it works fine. My question is do you think I could leave the jumper wire or can i put a standard 10k resistor to replace it?
Nope to just using wire. This is a thermistor or Fusable link. When the unit overheats due to slugish motor or left on for days on end it will blow.
You can get replacements a appliance repair stores.
Why replace the heater element unless it's broken. The thermal quit because of a fan motor or being left on.
The thermals go bad over time and when you purchase the heater element, the thermal is part of it. It's cheap, easy, and what is recommended by broan/nutone. There are few other heat lamp manufacturers around, but it's obviously quite possible that won't fix it.
