RGS PVC COATED
Alwayslearningelec
NJ
Estimator
Ok, I just want to confirm something. If I have 250' straight run on rgs or pvc coated rgs there is really no need for couplings and each section/stick of conduit will have a coupling and a threaded end. THanks.
petersonra
Northern illinois
engineer
I am pretty sure each stick of RGS comes with a coupling, but I seem to recall the PVC coated RGS does not.
petersonra
Northern illinois
engineer
IS that true about PVC coated RGS? THanks.
But don't trust my rememberer. It would be best to ask the supplier of the PVC coated RGS. It may be different for different suppliers. I know that at one time one of the PVC coated RGS suppliers used to include a can of the repair liquid with each shipment, but another supplier did not.
Cow
Eastern Oregon
You buy couplings seperate, the pipe only shows up with plastic thread protectors on both ends. Call a supply house if you want to verify it.
buddhakii
Littleton, CO
Not sure but I think it was Rob Roy that we got last year that had the couplings on and the coating was complete and smooth over the pipe and coupling. Never get it again though. Every single coupling cracked and broke the coating when tightening the conduit.
Okie Sparky
NW Oklahoma
The PVC-coated rigid conduit that I have installed has always came without coupling, then you get a box of couplings like are pictured in the link you provided and get busy. :happyyes:
wireguy8169
Southern Maine
Working at a waste water plant we use a fair amount of rob roy and it never comes with couplers when I have ordered it. I am glad it doesn't every time I look at the shelves and see how many RMC couplers I have laying around that I did not use.
WirenutNH
NH
When we order it it comes with the couplings, Maybe it is a supply house thing but we order 10' it shows up on slip as pipe only and it is delivered with 1 coupling for each stick
John120/240
Olathe, Kansas
Well if you don't have a Rigid threader on site, I would use a threadless coupling.
Say for example you have a 10ft stick of rigid and cut off two feet to make the run complete,
a threadless coupling is what you use.
Alwayslearningelec
NJ
Estimator
Thanks. And I'm sure spec dictates. But if you were plowed per spec I guess you would never thread when you cut a stick. That would be a waste of time, correct? Thanks
John120/240
Olathe, Kansas
It depends on the situation. Threadless couplings can be expensive to buy. Is there a threader
on the job site ? How many pieces of 85 & 3/4" conduit do you need ? What is your labor cost
per hour ? Two men with a porta band saw can cut & thread a lot of conduit in a couple of
hours.
Rule of thumb: due to cost save the threadless coupling for emergencys
