LowEnergyParticle
- Southeast Texas
Hello all,<br><br>I'm a new member here, and have read through a number of posts in the forum.  There are a lot of interesting topics and some very skilled and experienced people here!  I'm looking forward to learning a lot.  <br><br>I've got a little government-work after-hours project going on that I need some advice and clarification on.  My brother lives in the Frozen North, and has a small machine shop at his home in an enclosed but unheated room.  He's interested in keeping the machines from rusting, but is a notable cheapskate (particularly when it comes to paying the electric bill).  I've designed a small control panel that runs a 120 VAC oil-filled 1.5 KW (12.5 amp) heating element based on a calculation of ambient room temperature, machine steel temperature, and relative humidity.  The business-end of the of panel is just a single 25 amp SSR.  Since SSRs tend to fail shorted, I've programmed a high-temperature switch to open a contactor just upstream of the SSR: if the room achieves a temperature 15 degrees F above the setpoint, the contactor will open and drop the heater.  The contactor will not re-energize until the high temperature condition clears and a reset push button is pressed.  <br><br>Here's an ASCII version of the power one-line:<br><ol><li>20 amp single-pole breaker in the panelboard<br></li><li>20 amp receptacle adjacent to panelboard.  receptacle is 8 feet from control panel, and in line-of-sight.<br></li><li>20 amp plug wired to 2 feet of 12 AWG SOJ cable, spliced in utility box to 3, 12 foot lengths of 12 AWG THHN in conduit between panelboard and control panel.  <br></li><li>In the control panel, both the hot and neutral conductors land on the contactor (opens on high temperature)<br></li><li>12 AWG neutral conductor wired from contactor to simplex receptacle mounted on bottom of control panel<br></li><li>12 AWG hot conductor wired from contactor to output-side #1 of SSR<br></li><li>12 AWG hot conductor wired from output-side #2 of SSR to simplex receptacle mounted on bottom of control panel<br></li><li>!20 VAC oil-filled 1.5 KW (12.5 amp) heating element comes provided with a 2-conductor plug: plugged into simplex receptacle.  <br></li></ol>Here are my questions:<br><br>A.  Is the 20 amp breaker in the panelboard (item 1 above) sufficient for branch circuit protection, or must the control box contain another breaker?  The control box never branches again, there's only the 1 circuit, and the 20 amp breaker at the panelboard is sized correctly.  <br><br>B.  The SSR manufacturer wants a fast I^2T fuse on the output of the SSR.  The fuse and block cost quite a bit more than the little 25 amp SSR.  The heater will not have the 6x startup surge of a motor, and it also doesn't have to respond to load surges like a motor, so I'm kind of thinking that I should keep a replacement SSR around and not install the I^2T fuse at all.  Is this a violation?<br><br>C)  The transceivers and logic elements in the control loop are all mounted in the control panel and powered at 120 VAC.  I want to provide a 1 amp AG slow blow fuse to power the equipment, and have the fuse powered by jumping from the hot-side of the contactor in Step #4 above.  This seems fine from an ampacity view point, but I'm not sure if I've created a branching that would require an additional circuit breaker as in Question A above.  <br><br>I certainly appreciate any help offered, and thank you for reading this kind of long post!  He's a cheapskate all right, but he's a *GREAT* brother and I want to do good by him.  <br><br>Thank you,<br>Dave<br>
