So we can use panelboards with more than 42 circuits now?
I have a project where a 54 circuit panelboard would be perfect.
There are not too many companies making panelboards that have more than 42 circuits-- at least residential ones. I think Scott mentioned that Sq. D has a 60 cir. panel....
A number divisible by 2 which results in an even number, provides a balanced number or circuits per leg in a single phase panel.For some reason most resi panels only have 40 circuits, not 42. Not sure why but that is usually the case.
Good point but does that really matter? It might to the poco if all panels were loaded but I highly doubt it.A number divisible by 2 which results in an even number, provides a balanced number or circuits per leg in a single phase panel.
...That picture looks like a Canadian design, with the cover over the incoming line lugs.
I don't get it. A number divisible by 2 which results in an odd number would still provide for a balanced number of circuits.
Nevermind. With the staggered bus you couldn't really have a odd number of circuits.
He maybe could have worded it a little differently.
There is an even number of spaces with either 40 or 42.
There is however two more spaces on one bus than there is on the other.
42 works out well for three phase panels with same number of spaces per phase.
yeah didn't really think it through before replying :ashamed1:
Yes, I mentioned that but is that really an issue in the scheme of things. It is just as likely that the panel does not have 40 cir but 38.Because you would end up with 2 more spaces on the A leg is my guess.
