 - Massachusetts
Do you mean to say the the room - where the pictures are taken - is NOT fire rated but travel through the ceilings of the hospital to other rooms that ARE fire rated? If that is the case it would have been more cost effective to make the conversion AT the fire rating boundary. Just wondering what type of fire rated equipment would supply the panel feeders.
No I meant what I said, this room is supplied at 13.8 kV by protected feeders and from this fire rated room it is distributed to other fire rated rooms.
Do you not notice the block walls and the extensive use of fire stop?
