I am running emt conduit to pull a # 6 ground from ground rod to water main,  can I run insulated stranded to avoid corrosion or do I have to run bare copper. 125 amp service.  Also when the panel was installed the electrician did not install the bond to the water main so is it still ok to bond it this way since it will not be a continuous run with the #6, or do I have to redo the entire bonding run.
Thanks you guys are always very helpful
