Jennie1220
 - Tappahannock VA
 - electrician
I am going to install a PV system on a roof of a small office, but the power is going to be run down the side of the building and trenched underground to a small free standing 100amp panel.  The inverter is going to be mounted on the outside of the small office.  My question is all about grounding!  The small 100amp panel has a ground rod and I was planning on installing a ground rod at the inverter.  Can the PV system be tied into the build steel that is up in the crawl space or does it have to be run all the way down to the ground rod?  There is also going to be a combiner box up in the attic.  Does the ground from the frame of the pv panels go thru this combiner box?  I had planned on running #10 (black, white and green) from the combiner box to the inverter and the same from the inverter back to the 100amp panel.  Grounding these PV systems is extremely hard for me to figure out.  Thanks for the help
