Wyatt Earp
Here is the situation, I have a job where the electrician tapped off the 30 amp AC disconnect into a 2 circuit outdoor panel and installed a GFCI 2 pole 20 amp breaker for some 240 volt 20 amp snow melt cable which is controlled by a thermostat that shuts it off if the temp is above 40 degrees. Would this installation be code compliant since the thermostat would prevent the snow melt and the AC from coming on at the same time. Any help would be appreciated.
