Operating Temp Range
120105-1920 EST
I would not work toward the upper temperature rating. A higher temperature means a higher component failure rate.
At the low temperature end the likely failure is function rather than component.
120105-2006 EST
Transistor gains drop off at low temperatures. So this is the primary cause of low temperature operating problems.
Out of the hat I pulled up a datasheet for for a 7805 (5V 1A) regulator. For the non-military version they are showing -25 C. See http://www.fairchildsemi.com/ds/LM/LM7805.pdf .
More off the hat stuff. http://us.tdk-lambda.com/lp/ftp/Specs/ls.pdf If you really need 5 A, then I would choose a 10 A supply. This Lambda series appears to be rated for operation to -25 C.
