I'm looking for old transformer efficiency curves. Building was built in 1970 so basically between 1970-1990. trying to make a comparision between the old transformers and the new. Anyone know where I can get some? Looking for all types of kVA ratings.
thanks
A modern distribution transformer has maximum efficiency between 50% to 75% of its loading.So it is beneficial to load it in that range.
Could you please furnish the technical reference(s) for which you are referring.
I took it from
'Energy conservation in steel rolling mills' from ABI & ABI Publishers,India.
The following example also.
Suppose you have two 1000kva transformers and load is 500kw.It is better efficiency to operate the two transformers in parallel than using one transformer to supply the load.
I took it from
In 2005 the US passed an Energy Policy Act that required all general purpose transformers sold after 2007 to be designed to a target efficiency of a '24-hour average loading of 35%'.
There are also provisions, for non-general purpose transformers as well as large (i.e. >500kVA) units.
The rules, regulations and standard practices in the United States are certainly different than industry practices in India.
Isn't it unfortunate that the actual loading of an average transformer is likely 50-60% during the day and 10-20% at night, but the standard requires 35% which is not a value that the transformer actually runs at. I'm not sure what the standard should have been, but picking 35% seems wrong.
That 35% is a 24-Hr average. If you take 60% for 8 hrs, and 20% for 16 Hrs, you get a 24Hr avg of 33.3%. Pretty darn close.
Globalization process is on throughout the world.So The rules, regulations and standard practices etc., are bound to converge.
