ARC FAULT BREAKERS
domnic
Electrical Contractor
got a service call today on a house with two yr old siemens pannel with two arc fault breakers that were tripping i took the breakers out and water dripped out of the breakers i checked the other breakers in the pannel and they were all dry there was no sign of any moisture in the pannel itself. what could cause the arc fault breakers to have had water in them?
In operation for two years? A recent minor leak in Noah's ark? Trace where the conductors lead, you may find the leak.
A picture of panel and its surrounding might help.
I would double check for any dried moisture. Look for stains, waterlines, etc.
The only way water could have got directly into the breaker from outside was if it was installed with water in it, or it was sprayed with a direct hit afterward. (Sometimes HO's leave out little tidbits like breakers getting soaked from powerwashing or hoses and or pipes leaking.)
If the water leaked in through the panel or cables, there should be some evidence of that......you may have to look closer.
Higher the air temperature,greater is its ability to absorb moisture.On cooling down (low load times),it sheds its excess moisture.
Good point kwired. Maybe it goes back to comparing electrical theory to that of water and it realy is water flowing and not electrons at all, thus leaky breakers.
At lease they didn't let the smoke out.
If they had enough water in them to drip, and all of the other breakers were dry, I would say somebody was there before you and replaced the original ones with some they had laying in the back of the truck. Customers will lie from time to time. I had one that swore up and down that an outlet at the front of the store worked a couple of weeks ago. When I pulled it out, there was no wire to the outlet, and the conduit run ended at the top of the wall. The installing electrician had never completed the install when the building was built 3 years earlier.
Copper (and steel) thieves:happyyes:
