I had heard that someone ran into funny voltage readings on a home furnace, and traced it to a Quad 15/30/30/15 breaker that was used for a dryer sharing the 15amp breaker for the furnace. The prongs that attach the breaker to the bus were separated from what appeared to be excessive heat and not clamping onto the bus. By cleaning the oxidized bus with a file or emery cloth, are there any issues with damage to the bus plating finish that would affect the new breaker? Aside from the point of attachment and breaker, all appears to be ok in the panel. Thanks again.
