K8MHZ
 - Electrician
I would solve this problem as follows:
I = Vs/(r + R)
Where Vs is the source voltage, r is the load resistance, and R is the source resistance., then find the power, P.
P = r x Vs^2/(r + R)^2
then find the derivative,
dP/dr and set it to zero.
Now solve for r.
A little thought tells us that if the source is reactive, then the load must also be reactive, the complex conjugate of the source impedance so the reactances offset each other.
Why would we have to solve for 'r' if we know 'R'? (Jacobi's Law says they will be equal)
Where was it mentioned that the source was reactive?
