electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I have a tricky generator install that I am trying to figure out how to do and thought I would ask for feedback on what I am thinking of doing and also for any other ideas that I have not thought of. This job is for friends so I am trying to keep the costs down for them. The building is a multi use with 4 dwelling units (100 amp feeders), a shop space and a house panel. Service is 400 amp three phase 208, six hot sequenced meters (6 service disconnects, no single main). The shop space is the only three phase panel, rest are 208/120 single phase. They bought a used 3 phase 65 kw generator without discussing it with me so that is what we have to work with. The big question is how to tie this in to the system. My first thought was to get a 400 amp transfer switch and install it after a 400 amp single main but befor the meters. This is likely not feasible for three reasons: 1) cost. its about $4800 for the transfer switch and service disconnect. 2) issue with meters being neutral bonded. I know about the exception for cold sequenced meters, but with a trasfer switch in there not sure if that fits the exception. 3) Utilty probably will not like the meters cold sequences after transfer equipment, not to mention the transfer equip being non metered.
So my thought is to get 5 100 amp DPDT switches and tie them in after the meters. The shop panel may just not get emergency power or we will have to get a three phase switch for that one. So then I could run a single main feeder from the generator and taps off of that to each DPDT switch. Since the generator breaker is greater than 100 amps, I would need an ocpd after the taps but before the switch to protect the switch at its rating. Does that sound feasible or any other ideas? One more thing, they do have a 225 3 phase auto transfer switch that came with the unit but I cant see how that helps us (except maybe using it for the shop) Thanks.
