bphgravity
- Florida
This is the overhead service drop from the utility pole to the dwelling service...
What a crappy job, and that's not counting what they did to the drop.
Has an inspector of any sort seen that mess yet?
what about the 36" rule to service the meter pan.
This reminds me of a thing I saw in Poland a few years back on the news. People had a house built all according to code and passed all the inspections etc. but they had a situation with the phone company, which refused to remove an overhead cable - supposedly due to lack of funds. So these people ended up building the house with a 1/2" thick telephone cable running through four rooms on the second floor at about 5' off the floor and to make it all the more ridiculous, they were on the waiting list for telephone service. Evidently there was some conflict in the codes which allowed the people to build the house and allowed the phone company to refuse to remove the cable. In the meantime, they hung their laundry on it to dry. Finally, after the story made it to the national news, the phone company agreed to find the funds to move the cable. Video in Polish, but it's fun to watch anyway
Which rule would that be outside of local rules or POCO rules?
I believe blur is referring to 110.26.
What applies to 110.26 has been debated to death and no consensus of whether it applies to meter sockets.
Panel Statement: All electrical equipment requires sufficient access and
working space per 11 0.26. This includes metering devices. This is an
enforcement issue. CMP-1 refers the submitter to the NEC Style Manual,
Section 3.3.4.
You sure that is not some Polish joke? Haven't heard any of them for a long time![]()
True, I can only cite a 2008 CMP statement. It states my opinion.
90.2 Scope.
(B) Not Covered. This Code does not cover the following:
(5) Installations under the exclusive control of an electric
utility where such installations
a. Consist of service drops or service laterals, and associated
metering, or
I can only state what the words in the actual code say.
I thought this had been debated before.
The clearance for a meter base falls under 110.26. The meter base is customer owned equipment and is not under the control of the POCO.
The meterbase also falls under article 312.
Does an electrician not install the meter base and have it inspected?
The meter is the only thing owned by the POCO. The cabinet that the POCO installs their CT metering in also has to meet the requirements of 110.26 and 312, just to name a couple. It is customer owned equipment and has to be inspected by the AHJ.
The part about "and associated metering" applies to wiring practices, clearances on poles, etc. when the equipment is owned and maintained by the POCO.
I will have to get back to you. After reading some case law, WE BOTH may be arguing a very grey area that has no decisive conclusions. Although I will admit, the argument about sealing the base could put the enclosure exclusively under the POCO control. My concren here is IF the meter enclosure is under the exclusive control of the POCO, who is responsible for maintainance?It has and will be again.
And you have never dug your heels in to argue your opinion?It amazes me how hard people dig their heels in on this
Sorry jumper, he MAY have a convert. I am going to discuss this with some people tommorrow.
I haven't worked in all areas of the country, only been to Mass. for an ice storm a few years back, but around here, an inspector will fail an installation if the meterbase isn't properly mounted with the 1/4" air space and proper clearances. I have had one fail me because I installed the meterbase before the vinyl siding had been put on a couple of years back. (Now I use a "J block")I am going to ask their opinion and see if they are overstepping their authority.![]()
