blank face gfci somewhere in the room
Welcome to the forum.  The residential tubs with a motor under them need gfci as well as disconnect, so simple solution is gfci receptacle under tub.  However, most tubs that I've done have a cover on the side of the tub thats a bear to get back on once it's off.  So I use a regular receptacle underneath the tub for the motor cord and a blank faced gfci near the tub for the gfi protection.  If the motor needs work the cover has to come off anyway, and  the plug in the receptacle underneath by the motor takes care of the disconnect requirement.
